Hi, all, I found the Rtx51 Tiny source code in the \Keil\RtxTiny2\SourceCode directory. I can use RtxTiny2.Uv2 project to get new RTX51TNY.LIB. But I found RTX51BT.LIB is not produced, Keil use CopyLib.bat copy the old RTX51BT.LIB to \lib folder. Can anyone tell me how to set, so that I can re-compile RTX51BT.LIB. Thanks a lot.
Best Regards, Shunken
Just select the target "Code Banking" (from the Build toolbar or under Project - Manage - Components - Project Targets.
