Cypress CY7C68013A USB Bulk transfer problem
Hi Frnds,
I am using Cypress CY7C68013A EZ-USB micro controller, I have used BULKLOOP example given by cypress, where they have given a loop back transaction between EP2 to EP6, But I have changed the code for transmission of 64bytes of data as bulk on EP1, below code which i have written for bulk write operation, when i run this code it is transferring 64bytes of data ,but as a JUNK data, what is the mistake in this code, if there is any mistake please through some light on it.
 if(!(EP01STAT & bmEP1INBSY))
          //Source is Internal RAM Buffer
                memset(UsbBuffer,'\0',64);
        APTR1H = MSB(&UsbBuffer);
        APTR1L = LSB(*UsbBuffer);
        // Destination is External RAM at 0x2800
        AUTOPTRH2 = MSB(0x28);
        AUTOPTRL2 = LSB(0x00);
        EP1INBC = 0x40;   //64KB
        count = EP1INBC;// (EP2BCH << 8) + EP2BCL;
                SYNCDELAY;
        for( i = 0x0000; i < count; i++ )
           EXTAUTODAT2 = EXTAUTODAT1;
                SYNCDELAY;
//              EP1INBC = 0x40;   //64KB
                APTR1H = MSB(0x28);
        APTR1L = LSB(0x00);
                AUTOPTRH2 = MSB(&EP1INBUF);
        AUTOPTRL2 = LSB(&EP1INBUF);
                SYNCDELAY;
                SYNCDELAY;
        EP2BCL = 0x40;          // re(arm) EP2OUT
        u8TransmitFlag =1;
Rajesh
  • What do you mean by:
    For the high byte, you use the address-of operator
    For the low byte, you try to follow a pointer.
  • sorry it was aa mistake while typing, even after this the bulk transfer is not working!
            APTR1L = LSB(&UsbBuffer);
                    SYNCDELAY;
                    SYNCDELAY;
                    APTR1H = MSB(0x28);
            APTR1L = LSB(0x00);
                    SYNCDELAY;
                    SYNCDELAY;
            u8TransmitFlag =1;
  • Are you sure you should do:
    Why try to use macros to split a 16-bit value into a high and low byte, if you don't supply the 16-bit value in. What do you think MSB(0x28) is?
    MSB(0x2800) is expected to be 0x28. MSB(0x28) will just be 0.
    And please: Never, ever type your source code. If we can't trust that the code you post is the code you run, then why should we bother looking at the code.
  • Dear Per Westermark,
    Thanks for u r valuable suggestions, I have changed code according to as u said, it is now working fine, But there is one more problem now,
    I have used EP1 as IN transfer mode , i.e., EP1IN , but when i trasmit my buffet for first time i get JUNK, after I transmit for 2nd time onwards i get the what i am transmitting, I have checked many times, I get JUNK data first time and then the actual data, why it is happening
    . If there is any solution please tell.
            //      if(!(EP1INCS &0x02))
            //              while(!(EP1INCS &0x02));
                            count=EP1INBC;
                            for(i=0;i<count;i++)
                                    EP1INBUF[j]=gb+i+Inc;
                                    gb++;
                                    j++;
                            SYNCDELAY;
                            gb=0;j=0;
                            Inc++;
                            EP1INBC = 0x40;
                            SYNCDELAY;
            //              EP1INCS |=0x01;
                            ACC=XBYTE[0x9800];
                            SYNCDELAY;
                            ACC=XBYTE[0x8000];
                            SYNCDELAY;
                            ACC=XBYTE[0xB800];
    Rajesh
