Hi all,
I am using ULINK2 debugger for flash programming a TMS470R1B1M Evaluation board.Although I could able to program sucessfully.
The board stops working if re-cycle the power.I doubt wether the code is stored in RAM or FLASH.
Sometimes board stops execting the code even if I remove the JTAG connector.
Any special settings / configuration is required for storing in FLASH/RAM.
Also I removed the R4 from the evaluation board as suggested by KEIL.
Please post some tips to debug this issue.
regards PRAVIN T
