This is breaking my brain, a bit at a time... Code like this works perfectly:
void initSerialPorts(void){ EA=1;//enable interrupts ES0=1;//enable serial port interrupts SCON0= 0xD0;//put serial ports into mode 3 TMOD |=0x20;//put timer 1 into mode 2 TL1=247; TH1=247;//value to set timer to after it rolls over TR1=1;//start timer 1 running TB8_0=0;//9th data bit SMOD_1=1;//doubler bits for both serial ports PCON |= 0x80; EWDI = 0;//disable watchdog timer interrupt return; } void sample(void){ return; } main() { int x=1; P1=0x00;//complete LED circuit sample(); initSerialPorts(); P3=0x00; //ISDwait(); while(1){ x++; } }
The ports are being cleared to activate a pair of LEDs, because I can't seem to get the debugger to work properly. Code like this doesn't seem to return from the call to initSerialPorts():
main() { int x=1; P1=0x00;//complete LED circuit sample(); initSerialPorts(); P3=0x00; ISDwait(); while(1){ x++; } }
The two function definitions haven't changed. I suspect the call stack is being damaged at some point, but I don't know how. The code works perfectly in the simulator.
Because I'm a neophyte to the Keil products and microcontrollers in general, I strongly suspect a configuration error at some point. Should I also post the ISD51.H file?
Many thanks for any ideas, Bob Robertson
Okay, the code now works properly, at least, but the debugger isn't connecting. The notification reccs vs my actions:
-Check that I'm sending on the right COM port. Done, and I am (COM 2). -Check that the ISD51 is linked to my application. Done: the .A51 file is included in my project, and I have #include "isd51.h" at the head of my main program. -Make sure that the loaded application matches the ROM content: Almost certain that they're the same, but I've no way to know for sure. -Review the initialization of the serial interface re: baudrate. Initialization code is posted. I'm trying for 9600 baud using a 16.384M crystal, on a Dallas DS89C450. This works in the simulator at 9450-ish, so I think it's right. I'll keep checking it, though. -The application must not disable the serial interrupt for more than 5 seconds. It doesn't.
Frankly, this has got me pretty stumped. I've used a sniffer to verify that uVision is sending the right byte. I'll keep plugging at it, of course, but I could use the benefit of any experience you folks'd be willing to lend.
Many Thanks, Bob Robertson.
