Hello to all, I'm trying to use the mass storage example for the MCB2140 in DMA Mode but I'm not able to get it to work. In Interrupt-driven Mode everything works. But if I'm changing the flag for the DMA Mode for the endpoints 2 In or Out in the configuration wizard it doesn't work anymore. After examining the source code I recognized that no dma init function is called, no DDPs are set and no DDs are defined. Does somebody can help me in archieving this ? I tried already to change the sources but didn't have luck with it. Does somebody have maybe a changed example code ?
Any help would be appreciated
Wolfgang
