How do you stuff memory with 0x00 for the remainder of a hex file after the image file automatically?
I have tried to use an external file which I set to --last in the misc control under the Linker tab in options. However, it seems to limit the fill to a certain number of bytes, it will not fill the entire area. Any ideas or does anyone know if there is a command-line command that can be used?
srecord.sourceforge.net/
Is there a way to do this using the scatter file? I have been able to place files in the locations of desire successfully. But have been unsuccessful using the scatter file to stuff the remainder of memory.
