please if anyone have write code 8051 for sle4428 and read/write code to the card please send me sample source code. tanks
Which manufacturer/model of the '51 chip should the ARM emulate?
i dont known wath is 51 my chip? only this known that i have one pos unit that have reader gemcore and i work very good with COS cards but have prablems with memory cards sle4428. so i can write program with 8051 assembly code and i can read atr and firmware but i cannot read application area data from sle4428. my read byte data program is correct and i trace step by step ok. but the value return is not good and uncorrect. please help me what i doing? regards afe.
"i dont known wath is 51 my chip?"
That most basic piece of information is absolutely fundamental to your entire project!
You cannot hope to succeed without knowing precisely what chip you are using!
If you don't know what chip you are using, how do you know that it supports everything that you are trying to do? How do you know that you are operating it within its specifications?
You must find this out before you proceed!
in fact i known anything about this .but i want less speack about them. my chip is IC100(TSSop or SO) 24 pin dual interface and gemplus technologe this readers connect or embbedd with serial port and installed into pos and work with XSCAL(PXA255) cpu 44mhz. that this readers read and write COS(microcontroller)cards and memeory cards. but for syncrunouse cards must used 8051 code(iterperter interface layer). now i have problems with this soultion that write and devlop software that read and write into memory cards. best regards
