can't watch local variable
When I debug \Keil\ARM\RV30\RTL\Kernel\Examples\Measure\Measure.uv3,I want watch "cmdbuf[]" in Watch & Call Stack Window,when I use SARM.dll V1.5,watch data was right,but when I use SARM.dll V3.x,watch data was wrong.
  • remember that local variables aren't visible outside the function to which they are local; in fact, they may not even exist outside that function...
    Are you sure that this local variable should be visible at the time that you're looking at it?
  • Hugo, are you using the most recent version of the tools? Watch variables haven't worked right for me since I started using version 3.x of the tools either. As a matter of fact, I've given up using the debugger (for now) because of how bad the watch variable windows work, or should I say, doesn't work. My KEIL tech support session about the watch window not working ended with the realization that currently there were problems with the watch window.
    I recently downloaded & installed version 3.03a of the tools, and just realized that I hadn't tried the debugger since then. I'll try it and let you know if watch variables work any better for me now.
    Good luck.
  • Whoa...what a difference. Looks like watch var's are working well once again (in V3.03a), at least for me and my app. If you're not using V3.03a, I'd sure upgrade to it.
    Thanks KEIL !!
    Dave.
  • Thanks for this thread. I had been using the watch thing and it just didn't seem to work right. I have just upgraded and things appear to be improved. I have a question though. I can set values in Watch #1 and view variables etc fine, but when I go thru the edit - compile -debug loop I always loose the variables that I want to watch and have to re-enter them. Is there a way to make the Watch values "stick"?
    After update I see SARM.DLL v3.03, not v3.03a is that right?
  • I am running GNU 4.1.1, and one thing that the new version fixed was the ability to display bitfields correctly. However I lost the ability to do a mouseover on local variables and see their values correctly. Entering &varname into the memory window indicated that the debugger was looking in the wrong location since I could see the stack pointer in the register window, and could see that the debugger thought the variable was somewhere else. Manually entering the stack pointer into the memory window showed that the correct data was there, I just couldn't see it by doing a mouseover of the variable. Keil responded quickly to my support request and sent me a patch that fixed the problem. If you are using GNU and having problems, contact Keil support and ask for the patch (new version of SARM.dll) that resolves call #335962.
    Kathy
  • John, after installing V3.03a of the tools, the "help-about" dialog shows sarm.dll as v3.03, not v3.03a.
    Kathy, what does "help-about" show for your version of the sarm.dll file?
    Dave.
  • I am currently showing v3.03e. This is a separate SARM.dll file sent to me by Keil. It ends up in:
    <base keil directory>\ARM\BIN
    The info shown on the file itself in the actual directory is 3.3.0.1 for the one that came with the latest debugger update, and 3.3.5.1 for the new one they sent me.
    Kathy
  • Hi I posted too soon. The Watch does appear to be improved, the locals seem to work now where as before they didn't. But now if put a breakpoint after a string activity such as
    char cmdbuf [30];
    bla bla
    for (i = 0; cmdbuf[i] != 0; i++) { cmdbuf[i] = (char) toupper(cmdbuf[i]);
    and I hover over string arrays I get a stange looking yy which has two dots above each y. I had been playing with some string manipulation software just before the upgrade. I could see the string contents fine.....
    However if I change the declaration to
    static char cmdbuf [30];
    Things are fine again. I also wish that in the "locals and watch#x" windows that they had ascii as well as decimal and hex.
  • Static works, thanks..
    But there are other problems.
    I made this function:
    void Main_make_sprintf_work(char * str)
      static char str_local[40];
      sprintf(str_local, "%f" ,2.45);
      memcpy(str, str_local, 10);
    It works when I call it from main() but don't work if the call come from a function further inside the program.
  • In what way does it "not work"?
  • When I call Main_make_sprintf_work(char * str)
    from a task, str_local don't contain the right string.
    After adding 500 bytes to the stack (now 1500 bytes) it writes "2" in Str_local.
    I think its strange it did not detect any stack overflow and why do it need so much stack?
  • The problem was that I had an RTX_Config file for V3.02 and my IRQ and USR stack size was too small.
