Catching memory leaks
I have some code running on an 8051 based processor that is quite large and complex and it also uses a few arrays. To make sure that I can avoid mistakes accessing memory location that do not exist, I'd like to know if there are anyway to get the C51 Compiler to catch this type of mistakes.
BYTE xdata myArray[8]
BYTE i;
for (i=0;i<10;i++)
    myArray[i]=i;
The compiler has no problem with that and doesn't report memory leaks. Are there any ways to make the compiler to generate an error or even a warning?
