I am looking for generating an iterface between 1-wire digital thermometer DS18B20, using DS2480B Iine driver and the ARM7 LPC2138 using keil, where I can read different temperature detected by the sensor and output it on the hyperterminal. Can anybody help. Has there been any work done in this area
The DS2480B allows you to control a 1-Wire bus via an RS232 connection:
www.maxim-ic.com/.../2923
So, as far as the ARM is concerned, it's simply a matter of sending & receiving data via a UART!
"Has there been any work done in this area"
Yes - there is a vast body of experience in sending & receiving data via UARTs!
www.maxim-ic.com/.../2923 Provides a whole list of Application Notes relevant to the DS2480B.
www.maxim-ic.com/.../2812 Has an even longer list of Application Notes relevant to the DS18B20.
