Are Keil ARM tools [C-ARM and keil IDE] supports c++ types and features.. like class, inheritance, polymorphisom etc..
Can anyone guide me regarding this
Best regards, Mittal
If it was a C++ compiler, they wouldn't call it a 'C' compiler, would they?!
http://www.keil.com/support/man/docs/ca/ca_intro.htm
They do, however, call RealView a "C/C++ Compiler":
http://www.keil.com/arm/realview.asp#compiler
For further details, I guess you should call Keil sales to discuss your requirements:
http://www.keil.com/company/contact.asp
Okay, Got the point.
If I talk about perticular requirment, I need only Class, and inheritance for my device [driver]class. But only for that I dont want to go with armcc
By the way Thanks, Andy
-Regards Raj
The RealView compiler is a full-featured ISO standard C++ compiler. It supports everything including Templates.
"The RealView compiler is a full-featured ISO standard C++ compiler"
What revision of the standard?
For 'C', is that C89, or C99?
Similarly, I don't think I've ever seen it clearly stated what revision the C51 compiler follows...
The RealView Compiler is ANSI C99. All other Keil Compilers are C90 with some language extensions. See: http://www.keil.com/support/docs/1893.htm
