Hi, i'm tring to program the flash of an ARM based development board from Texas Instruments.
The keil Microvision shows the following error message : "Cannot Write to RAM for Flash Algorithms"
The address segment for the Flash and Ram seems to be ok.
Ram for algorithm : Start Address : 0x20000000 Size : 0x0F00
Has anyone ever had this problem or knows how to solve it ?
Thank You.
I've found an information about it on the Technical Support at http://www.keil.com/support/docs/2747.htm
However, it says the RAM address range only for the Philips LPC2000. I'm using texas TMS470R1B1M and haven't found anything about the RAM area that I could download the flash algorithm.
