Why does UV3 name its project and backup files with the .UV2 extension?
This is a problem for me since I run both UV2 and UV3 projects.
Is there a fix for this or is one currently in the works?
Thanks, Brian
Forget it...My problem. My file types and extensions got all messed up by having both Uv2 and Uv3 installed. I fixed it by manually changing file types and extensions in windows.
Ok, let me just continue this conversation with myself...
Apparantly, it is still a problem. I can manually change extensions and such, but every time I close UV3...it creates a new project file and gives it a Uv2 extension.
This is a problem for me.
Why, UV2 files work on both UV3 and UV2.
I could never open a Uv2 file with Uv3. It always stated the ToolChain path was missing.
So I just opened the Uv2 Tools.ini and cut and pasted the [C51] path info into the Uv3 Tools.ini. This seems to have worked fine and I can now use Uv3 to open my old Uv2 projects.
Thanks.
I guess you mix versions (i.e. C51 Version 7.5 with MDK-ARM Version 3)
