Hi to all!
I installed the driver for virtual ICE with proteus vsm and Keil, I followed the instructions on the .pdf then tried to run the calculator example. Everything seems to be ok and when I start the debugging on keil, the simulation runs on proteus and after about 0.5 sec Keil shows an error: Target dll has been cancelled, debugger aborted.
Would you please help me solving this problem.
Thanks.
