Size of flash memory
Program Size: data=63.0 xdata=0 code=1832
How do i calcuate the size of flash memory of controller required for the above program size?What does the above information indicate?
P.S.:The program was compiled in Keil UV2
  • your code size is 1832 bytes long
    your code is using 63.0 bytes of the RAM
    And you are not using any bytes of the XRAM
    ...How do i calcuate the size of flash memory of controller required for the above program size...
    It should greater than code size.
  • code size + constants size. (Constants, including C initializers, have to be stored in non-volatile memory.)
    "data" refers to the internal 128/256 byte data memory space of the 8051. "xdata" refers to the 64KB external memory space.
