breakpoint definition error
When trying to set a data write access breakpoint, I keep getting the message "breakpoint definition error".
I go:
Debug->Breakpoints
In the dialog, under Expression, I put
Switches[]- This is an array of bytes in my project, and I am succesfully monitoring it in the watch window
Under Access, I check Write, Size = 1, and check Objects (I've also tried Bytes and got the same result)
I then click Define and up pops the error messasge.
What am I doing wrong here?
