Hi there, I'm usiing the u-vision and the U-Link JTAG to program LPC processors, and till now I've never had problems programming the LPC2106, but I just switched to LPC 2104 and it simply just doesn't work, eventhough they are compatible, beside the ram size.
I can see that there are both an IAP and IAP-2 algorithm to use, but untill now I haven't found out what the fifference is and which algoritm to choose.
So, what algoritm is the correct one, and what is the difference between those 2?
Cheers Adrian
The LPC2104 devices require the IAP algorithm. The IAP2 algorithm is for the LPC2101/2/3 and LPC213x or higher.
Super - Thanks for your help :-)
