Hi!
I am try to wake up after 1 minute using RTC(Real Time Clock) on XC164CS(. I checked sleep mode is working well, but I think some settings are missed. When I read the user manunal especillay RTC part, I found a clue when user enter the sleep mode the system clock stop completely and the RTC would stop counting. In this case RTC can be switched to Asynchrous mode. Firt time I set synchrous mode(defualt setting) which is setted by DAVE. and it does not wake up. And then I try to change Asynchronous mode, It also did not working. I think it may be missing. Please let me know what is the problem?
E-mail : hssong@katech.re.kr
Below is my test program.
// RTC function // 1 min RTC interrupt setting void RTC_vInit(void) { MAIN_vUnlockProtecReg(); //unlock SYSCON0 SYSCON0_RTCCM = 1; // disable access to control bits while((RTC_CON & 0x8000) == 0x8000); RTC_CON = 0x0002; // load RTC control register /// - overflow period on T14: 1.0000 [s] /// - overflow period on CNT0: 1.0000 [min] /// - overflow period on CNT1: 1.0000 [h] /// - overflow period on CNT2: 1.0000 [days] /// - overflow period on CNT3: 1.0139 [years] RTC_T14REL = 0x85EE; // load T14 count/reload register RTC_RTCL = 0x13C4; // load RTC low register RTC_RELL = 0x13C4; // load RTC reload low register RTC_RTCH = 0xA4E8; // load RTC high register RTC_RELH = 0xA4E8; // load RTC reload high register // ----------------------------------------------------------------------- /// Configuration of the used RTC Interrupts: /// ----------------------------------------------------------------------- /// RTC service request node configuration: /// - RTC interrupt priority level (ILVL) = 7 /// - RTC interrupt group level (GLVL) = 0 /// - RTC group priority extension (GPX) = 0 RTC_IC = 0x005C; RTC_ISNC = 0x0004; // load RTC interrupt sub node register } // RTC Interrupt routine void RTC_viRTC(void) interrupt RTCINT { if(RTC_ISNC_0IR) // if counter CNT0 overflow { RTC_flag = 1; RTC_ISNC_0IR = 0; } } // End of function RTC_viRTC // main() function void main() { // 1 min RTC Interrupt setting RTC_vInit(); // RTC RUN RTC_CON_RUN = 1; // Enter sleep mode Enter_Sleep_mode(); // it is user coding , its ok // After 1 min. RTC wake up if(RTC_flag == 1){ printf("RTC wake up OK \n"); } }
