Hello All,
I was looking at EPM900 manual. It says this is ISP programmer for LPC9xx devices. But it does not list LPC952 in supported devices. I have an EPM900 with LPC936 bondout with me. Can I ICP program LPC952 using this? I dont find this device in device list as well, So if I choose a device with 8k flash, and disable ID check, will I be able to ICP LPC952?
Regards Umesh
FlashMagic free from http://www.eascademy.com
of course if you are an IDEiot, you are lost
Yes, I know about flashmagic and that is what I am using currently. But I have messed up with ISP of some LPC952s and I have to change the uC when that happens. So I was just wondering if I can do ICP with LPC952 (I also have one EPM900 with me) Hence the question.
Regards Umesh.
FlashMagic can be used via the IDE!
well, that's nice
EPM900 supports LPC90xx - LPC93x. It does not support LPC95x or onwards. You need currently the FS2 Debugger (or FlashMagic) to perform flash programming with this devices.
