EasyWEB work fine on MCB2300 when I press reset button. After disconnect and next connect power supply web page does not show. I must press reset button always after connect power supply and then works OK.
Do you have similar symptom?
Keep in mind: the EasyWEB example is a free example that shows you just some basics (such as the interface to the Ethernet controller). You will find several shortcomings with this product when you look deeper.
A commercial product is the TCPnet suite in RL-ARM. An example is provided under: http://www.keil.com/download/docs/328.asp
Does this example show also the RESET problem that you are describing?
Unfortunately I don't have RL-ARM license and I can't run TCPnet example. Can someone tell me that have this same problem like me with this EaseWeb example? Becouse I don't know is it trouble with hardware or software.
You can download an executeable RL-ARM HTTP Demo example from: http://www.keil.com/download/docs/328.asp
This zip file don't contain hex or bin file.
But it does contain AXF
