the ULINK cann't program the Embedded Artists LPC2468 OEM borad
I use keil and ulink tool, I want to test the LPC2468 code on EA LPC2468 OEM board, after the project is compiled correctly, I click the load button in keil, the screen display a message box, the content:"Cloud not stop ARM device! please check the JTAG
cable".I am really sure that the ULink is ok, because I can use it debug the keil 2140 board. I check the jump on board. the Enable JTAG is closed, so it is correct. I don't know what is the reason. do i need
change the ULINK to ULINK2?
anyone has any ideals? Thanks in advance.
