Is it possible to locate different parts of the same library in different banks. It seems like linker will locate the whole library in one code bank only.
Thanks in advance
When you split your project into two parts you can do this. Take a look here:
http://www.keil.com/appnotes/docs/apnt_180.asp
DEAR I AM DEALING WITH THE 80 BIT DATA USED BY 80 BIT SHIFT REGISTER NOW I WANR TO DRIVE 8 BIT SHIFT REGISTER WITH THAT DATA CAN YOU GIVE ME THE TIPS FOR THIS CONVERSION. I WANT TO USE AT89S51. THANKS
DON'T SHOUT!
Writing in ALL-CAPITALS is hard to read - and it's considered to be SHOUTING. Don't do it!
and don't hijack a post.
What does your question have to do with code banking?
