4 x 7 Segment Display Multiplexing
I am learning 8051. I know the theory behind 7 segment display multiplexing but do not know how to code in C. Please give me code for 4 x 7 segment display multiplexing.
I am using 89S51 and will use P0 and P1 for display. And my display are common cathode (CC). Please do the need full.
  • Please give me code
    This is a forum for programmers not for copiers. If you need to cheat to pass your examp, I hope, for the sake of the industry, that you do not pass.
  • I am using 89S51 and will use P0 and P1 for display
    P0 and P1 can not source/sink enough current to give you a bright Display. So you have to use a driver IC.
    Take a look to MAX7219 on http://www.maxim-ic.com
    Here is my example-Programm
    //  C-Programm for driving a MAX7219
    //  a 8 digit number is printed in a string (sprintf)
    //  and then send to the MAX7219
    #include<c8051f200.h>
    //#include<math.h>
    //#include<string.h>
    #include<stdio.h>
    sbit Data7219 = P1^0;
    sbit Load7219 = P1^1;
    sbit Clk7219 = P1^2;
    const unsigned char Font_B[16]=
            0x7e,0x30,0x6d,0x79,0x33,0x5b,0x5f,0x70,
            0x7f,0x7b,0x77,0x1f,0x4e,0x3d,0x4f,0x47
    void Send7219 (char,char);
    void Send7219byte(char);
    void MAX7219init();
    void Display(unsigned long int);
    void main (void)
            MAX7219init();
            Display(47110815);//my_weird_number
            while(1){}
    void MAX7219init()
            Data7219 =0;
            Load7219 =0;
            Clk7219 = 0;
            Send7219(0x09,0x00);//Decode Mode
            Send7219(0x0A,0x05);//Brightness
            Send7219(0x0B,0x07);//Scan limit
            Send7219(0x0C,0x01);
            Send7219(0x0F,0x00);
    void Send7219 (char Digit,char Data)
            Send7219byte(Digit);
            Send7219byte(Data);
            Data7219=0;
            Load7219=1;
            Load7219=0;
    void Send7219byte (char byte)
    unsigned char I;
            for(I=0;I<8;I++)
            if (byte & 0x80)
                    Data7219=1;
            else
                    Data7219=0;
            Clk7219=1;
            byte<<=1;
            Clk7219=0;
    void Display (unsigned long int My_number)
            unsigned char i,string[8];
            sprintf(string,"%8.lx",My_number);
            for (i=0;i<8;i++)
                    if (string[i] == 0x20)//0x20 is ASCII " "
                    Send7219(i+1,0);          //send MAX7219 " " to MAX7219
                    else    if (string[i] <= 0x39)
                                    Send7219(i+1,Font_B[string[i] - 0x30]);//0-9
                                    else
                                    Send7219(i+1,Font_B[string[i] - 0x57]);//A-F
  • "So you have to use a driver IC."
    Well, you don't have to use an IC - you could use discrete transistors...
  • i will use discrete transistors the day, the hell is frozen ;-)
  • For my display driver, I use vacuum tubes.
    This has the beneficial side effect of making the 8051 seem very modern and advanced by contrast.
  • ... and also warms the room on a chill winter's evening...
    This has the beneficial side effect ...
    Another benefit is that no current is required to drive the grid, just voltage.
  • "Another benefit is that no current is required to drive the grid..."
    Just as well - cos all the current is being used up in the heater supply!
    (6.3VAC, of course...)
  • (6.3VAC, of course...)
    No, I make portable equipment, so I use 6.3V DC
