Call functions
I have some assembly routines located in ROM memory, for example asmfunc that is located at address 0xF700 - is absolute address of flash memory.
The program memory is organized:
ROM code from address 0xF000 - 0xFFFF
Flash code from address 0x0000 - 0xEFFF
I have my C code and I want to call from C the assembly function asmfunc located at address 0xF700, how I can do this?
I know to call function asmfunc if my code is in Assembly using for example this:
asmfunc equ 0xF700
lcall asmfunc
Thanks,
Nels
  • Consult you copy of the manual, look up C<->asm interfacing.
    For a generic assembly function, it's not clear that it can be called from C in the first place. If it doesn't follow the C51 calling convention, nothing you do on the C side can fix that.
  • Assuming the routine takes no parameters and returns no value, something like:
    typedef void (* VFPV)(void);
    int main(void)
        ((VFPV)0xF700)();
        return 0;
  • The C convention is that function names start with an underscore. So, name your asm functions accordingly, and export the names of the functions with "public".
    Asm.a51
    PUBLIC _AsmFunc
    _AsmFunc:
            RET
    Asm.h
    extern void AsmFunc (void);
    C.c
    void main (void)
        AsmFunc();
    If you're trying to jump to a particular address that you maintain manually, rather than letting the linker do it for you as above, then you can do something like: #define AsmFuncAddr 0xF700 *(AsmFuncAddr)(); to cast the integer constant to a function pointer and call the function. Generally if you go this route, it's a good idea to have vector table so that there's only one hardcoded address.
  • "The C convention is that function names start with an underscore."
    C51 also has other conventions - you must read the Manual...
  • Hi,
    First of all I read the manual. I think the problem is not "underscore" in assembly function but:
    My flash memory is mapped 0x0000-0xF000 for flash code, 0xF000-0xFFFF this address is re-mapped to other memory - ROM memory, here I have assembly code with some routines.
    so in my case I have two firmware projects! one project_rom.Uv2 written in assembly located in ROM, other project_flash.Uv2 located in the flash.
    I would like to call directly some assembly routines located in ROM from "C" in the flash memory --> that corresponds to the project_flash.Uv2
    Thanks you.
