simulator peripherals limited in uVison3 Eval Version
I can´t see the changes in the CAN registers when using the simulator. The GPT2 Timer 6 is running well and is visable. But in the CAN1 Menu everything is greyed out. I´m using DAvE to generate Software for the Infineon C167CR.
Is the Simulator in the eval version limited? So that it is not possible to watch the registers and the message objects? I also double checked the register addresses in my program. So this can´t be the problem.
Can anyone help me. Thanks
chris
