How to place assembler function in ram
a function could be placed in ram by assigning the
__ram switch.
How to do this for assembler functions?
// 32*32 bit signed/unsigned multiply in ARM Assembler
// Returns 64 bit result in R0,R1
AREA ?C?bla, CODE, READONLY, ALIGN=2
PUBLIC S_MUL32x32?A
S_MUL32x32?A            PROC CODE32
                SMULL   R2,R0,R1,R0                     ; R0,R2 := R1*R0
                mov     R1,R2
                bx      lr
                ENDP
PUBLIC U_MUL32x32?A
U_MUL32x32?A            PROC CODE32
                UMULL   R2,R0,R1,R0                     ; R0,R2 := R1*R0
                mov     R1,R2
                bx      lr
                ENDP
                END
maybe there is a chance in the red line.
i'm not sure i just copied this line from an example-programm...
  • Hello to everybody,
    sorry when my question looks like fake, but
    i'am really despaired.
    So would be nice if somebody gives my a hint.
    AREA ?C?bla, ERAM, READONLY, ALIGN=2
    I want to have the Assembler code in RAM for speed.
    But when i replace "CODE" with "ERAM" i get error A9 syntax error.
    SOS
    CQD
  • You need to use the scatterloader and load the whole module into RAM (that is if you are using the RealView compiler, the __ram switch is old)
    It will look something like this
    RW_IRAM1 0x20000000 0x00010000 { ; RW data assembly.o (+RO) * (+RW +ZI) }
  • Hello thanks for reply :-)
    But sorry, i dont use the realview-compiler,
    i use CARM, this was recommended by the getting-started-guide of my evalution-board.
    This is my C-code, but how to tell the compiler, that i want the assembler code to place in ram to get a little speed up. This is just an example to develop the method.
    Maybee there are several methods to speed up:
    __inline attribute
    __ram attribute
    __task attribute
    #include<ADuC7026.H>
    #include<STDIO.H>
    void PLL_init(void);
    void RS232_init(void);
    extern unsigned long long U_MUL32x32(unsigned int,unsigned int);
    extern unsigned long long S_MUL32x32(unsigned int,unsigned int);
    union xyz
            unsigned int i[2];
            unsigned long long l;
    int main (void)
            PLL_init();
            RS232_init();
            while(1)
                    union xyz zz;
                    zz.l=U_MUL32x32(0x88888888,0x22222222);
                    printf("%#.8X ",zz.i[0]);
                    printf("%#.8X\n",zz.i[1]);
                    zz.l=S_MUL32x32(0x88888888,0x22222222);
                    printf("\nPress a key\n");
                    scanf("%*c");
    __inline void RS232_init(void)
            GP1CON = 0x011;                 // Setup tx & rx pins on P1.0 and P1.1
                                            // Start setting up UART at 115200bps
            COMCON0 = 0x080;                // Setting DLAB
            COMDIV0 = 0x00B;                // Setting DIV0 and DIV1 to DL calculated
            COMDIV1 = 0x000;
            COMCON0 = 0x007;                // Clearing DLAB
    __inline void PLL_init(void)
            unsigned int n;
            PLLKEY1=0xAA;
            PLLCON=0x01;            //clear Bit5 OSEL => External 32.768kHz crystal
            PLLKEY2=0x55;
            for(n=0;n<1000000;n++){}        //wait for PLL run proper
  • Your Assembler functions as they exist (as I have seen in previous postings), are fully relocatable.
    You may copy them to as section of RAM and call them by function pointer. I think they would be 12 bytes long each (if the UMULL/SMULL fit in 32 bits)
    u32 UMULL_EXT[3];
    u32 SMULL_EXT[3];
    typedef unsigned long long (*RAM_MULL_CALL)(u32 a, u32 b);
    for (i = 0; i < 3; i++)
    { UMULL_EXT[i] = ((u32 *) &UMULL_32x32)[i]; SMULL_EXT[i] = ((u32 *) &SMULL_32x32)[i];
    to call
    zz = ((RAM_MULL_CALL) &UMULL_EXT)(number1, number2); zz = ((RAM_MULL_CALL) &SMULL_EXT)(number1, number2);
