lib 91x_it.h interrupt definition
Hi all,
I want to have a timer1 interrupt every 1mS on my MCB-STR9 demo board.
To do this , I init Timer 1 as output compare.
In my interrupt routine I increment my compare register with a value correspondig with 1mS.
This works fine as long I use the __irq prefix before my interrupt function.
However, when I do this, the compiler gives an error :
declaration is incompatible with "void TIM1_IRQHandler(void)" (declared at line 44 of "C:\Keil\ARM\INC\ST\91x\91x_it.h").
I do not have that error in the blinky demo.
Whats wrong ?
Luc
