Goto
Hi
Can I use GOTO statement in interrupt routine?
Example code is:
#include <REG51.H>
void ex0_isr (void) interrupt 0 /*external interrupt routine*/
goto NEXT;
void main(void) /* main program*/
IT0 = 1; // Configure interrupt 0 for falling edge on /INT0 (P3.2)
EX0 = 1; // Enable EX0 Interrupt
EA = 1; // Enable Global Interrupt Flag state
While(1) /* loop1*/
; ; /* interrupt well occur in this loop */
NEXT: while(1) /* loop2 */
Normally interrupt well occur in one loop after exciting the interrupt service routine
Again it well come to same loop. But my use is interrupt should come in one loop after that it should goto to next loop that's why here iam using GOTO state ment.
Can you give one example?
How to generate a interrupt in one loop and send into other loop.
Regards
Nattu
