I am trying to create a DOS batch file that allows me to program a FLASH device. This is for production release. The command line is as follows : uv3 -f project.uv2 The problem is that I need to have the target reset before programming can commence. If I do the programming manually, I need to enter debug mode and reset the target, exit debug and then program the flash. Any ideas? Regards marcus.
Two things may help: a) in the Flash project try to enable Project - Options - Debug - ULINK Settings - Use Reset at Startup b) make a separate "dummy" project that just starts the debugger, issues an reset, and then EXIT.
Project - Options - Debug - ULINK Settings - Use Reset at Startup Looks like it works !! thanks for that. I did think of creating a dummy project - was next on the list of things to try..! again, thanks. Marcus.
