using ISP read memory command
Hi guys,
I am trying to use ISP command to control LPC2103 from embedded system. I managed to start LPC2103's ISP handler and run some ISP commands. Trouble is once I run "Read memory" command, it seems that LPC2103 does not respond at all to any ISP command after that.. Anyone experienced this problem?
Is there a direct support in Philips?
TIA
