Hi.
I'm using the LPC2103 from NXP. When I want to set the SPI1 register SSPCR0 (which is located at address 0xE0068000) the simulator responds with a "Data abort".
The same situation occurs with ADCR at address 0xE0034000. Has anyone an idea how to solve this problem?
The LPC2103 is today not fully simulated. We are currently working on update simulation that will cover the new LPC2300/2400 and the LPC2103 variants. It should become available in April, but most likely we will publish an early version sooner.
