Hi i have changed some working example code for the nrf24e1 to now send 144 bits:
This is the new configuration:
const RFConfig txconf = { 15, 0x00, // Payload size receiver Rx #2 (not used in this example) 0x90, // Payload size receiver Rx #1 0x00, 0x00, 0x00, 0x00, 0x00, // Address receiver Rx #2 (not used in this example) 0x00, 0x87, 0x65, 0x43, 0x78, // Address receiver Rx #1 (four lower bytes used here) 0x21, 0x6f, 0x04 }; const RFConfig rxconf = { 15, 0x00, // Payload size receiver Rx #2 (not used in this example) 0x90, // Payload size receiver Rx #1 0x00, 0x00, 0x00, 0x00, 0x00, // Address receiver Rx #2 (not used in this example) 0x00, 0x87, 0x65, 0x43, 0x78, // Address receiver Rx #1 (four lower bytes used here) 0x21, 0x6f, 0x05 };
as can be seen the 0x90 is the 144 bits of payload. There are 4 bytes = 32 bits (0x87, 0x65, 0x43, 0x78) address. CRC is now enabled at 8-bit and address width is set to 32-bit (0x21). The original configuration worked fine for sending 1 byte and flashing an LED perfectly, now the problem is that the LED flashes continuously even when the transitter is off and reset. I cant see any problems why this shouldnt perform the same function as the basic example.
any ideas? and yes i have looked at the data sheet.
