Is there stand alone programmer software that uses the ULink or ULink2? I need to program LPC2129s without using the uVision.
Thanks! Chris
yes,FlashMagic, free from http://www.esacademy.com. (financed by Philips)
why would you want that?
Well, I have a customer that needs to update a board I did using an LPC2129. I can't get the bootloader to work and money is not an issue. I've always used a ULink through uVision to update the boards but need a stand alone software that my customer can easily use. It looks like Flash Magic uses the bootloader not the ULink? What else can I try? Thanks! -Chris
Use uVision in batch mode from the command line; you can use the EVAL version, license is not needed to program devices with a file of any length
http://www.keil.com/support/docs/3061.htm
Which is a bit annoying, since you do have to install uVision to get the programmer working...
