Problem with AT89C51ED2 --EEPROM!
Hi Keil,
I have written the follwing code for writing the byte in EEPROM in ED2. The Problem is BUSY flag is not being cleared.
while(!(EECON & 0x01)) ;
EA = 0;
EECON |= 0x02;
XBYTE[0X0055] = 'C';
EECON |= OxOO;
EA = 1;
Please provide the suggesion.
  • Well, at least you've learned to use the 'pre' and '/pre' tags in the 3 days since you last posted this:
    http://www.keil.com/forum/docs/thread8182.asp
    But what do you suppose that this line would actually do:
    EECON |= OxOO;
    even if it did compile?
    always use copy-and-paste from your actual source file when posting code; never manually re-type the code into the forum!
  • hi,
    EA = 0;
    EECON |= 0x02;
    EECON |= OxOO;
    EA = 1;
    First of all, you should wait till EEBUSY has been set to zero. Your while() waits for the flag will be set to '1' -- that's wrong.
    Another issue is: to disconnect EEPROM you should use AND but your code shows OR.
    In sum:
    while(EECON & 0x01)
    EA = 0;
    EECON = 0x02;
    EECON = OxOO;
    EA = 1;
    If the code above is still not work please post assembly code generated by compiler.
    Regards,
    Oleg
