Why this bug occur?
C51 V8.05a
The new uVision 3.33 editor
when a line contain space, the cursor's position indicate error behind space,
why this simple error occur, is you not check at all?!
  • "... is you not check at all?!"
    By "you", I guess you are referring to "me"?
    So then, my experience has been that if one simply leaves the errors out to begin with, that these little annoyances are avoided altogether. It's been working wonderfully that way for decades.
  • "when a line contain space, the cursor's position indicate error behind space"
    There must be more to it than that!
    It would be impossible to write any 'C' program with an editor that wouldn't allow any spaces!
    Post the smallest complete example that illustrates your problem, remembering to read and follow the instructions on how to post code.
    Use copy-and-paste - do not manually type the code into your post!
    Also post the full text of the error message(s)
    "is you not check at all?!"
    Who do you mean by "you"?
    If you mean to address this to Keil, you are in the wrong place!
    See: http://www.keil.com/forum/terms.asp (4th bullet-point)
  • We really do not understand this problem? Can you send further information (perhaps a picture) to
    support.intl@keil.com
