How to change AR166 library default location?
I have a project that uses ARTX166. Microvision always tries to link the project with the library located in the .../keil/lib folder.
However, I want the library file to be physically located within my project directory, not in the default Keil library directory (for version control purposes, and also because I work on several different projects that may use several different recompiled kernels).
The Keil support claims that it is not possible to have Microvision tell the linker to use an alternate library. Can anybody confirm that?
Thanks and regards,
-Stephane
  • A quick update on that matter:
    The Keil support team pointed out that a workaround is to move all the libraries needed for the project in another folder and change the options in "components, environment and books"->"Folders/Extensions"->"Development Tool Folders".
    That will work too.
    -Stephane
