Problem with reset....
I have a problem with a LPC2129 on one of my application. In fact I've made a programm using an external interrupt pin and when using in normal conditions all is ok. The problem is when I shut down the power supply. I have to make a reset manually otherwise my cpu is blocked. When I perform the reset manually my programm is working. What should I do to resolve this problem ?
Thanks for your answers
