As you are probably now aware, we have implemented a new discussion forum format that fits in better with the web site design.
All prior forum threads have been moved over and are available. The old links to them even work (so you can still find information on Google and other search engines).
We have added a few features with regards to formatting. These are available under settings.
Please reply to this thread with your comments and suggestions.
Thanks, Jon
I just saw http://www.keil.com/forum/docs/thread8203.asp which confirms my previous post re placement in subfora. It is about the ST10F276 and the toolset is stated as 'none'. It even states "I tried to change it in START167.A66" and I TRULY wonder how that was done with no toolset.
I don't seem to receive emails anymore, when somebody posted an answer or in a thread. I did select the checkbox. Normally I received an email (confirming mypost) within a second after I posted something.
Does anybody else have this problem?
Regards, Joost Leeuwesteijn
The search function don't regard the settings of Product family. I get a lot of threads from NONE ,C51 and C166 when I'm searching inside the Arm7 tools set.
Can you give me an example of the search query and the response that souldn't be there?
I checked the search results pretty thoroughly a while back, we fixed some problems, and I was pretty sure everything worked correctly.
Jon
Yes ,I am experiencing same thing..
Thanks for saying something. This feature should be working, now.
now, Jon, since you want suggestions how about a 'double click preventer' :)
That's already on the list.
the forum format allow insertion of a reply in the middle of a thread which, often, is a good thing.
a small request: could you make the 'new post marker' more blatant so those of us for whom 20/20 vision is but a faint memory can spot the new posts without straining?
Erik,
I was thinking the same thing. It's done.
express service, I'm impressed
Thanx,
now, it was still 'fat' in the threadlist, but no new posts (yellow or otherwise) was there
Hi Jon, you need an example? Start the advanced search and select a Product Family: Arm7,ARM9, and Cortex-M3 Products Fill in Search for with something e.g. finction pointer. As Categories select only forum. Than search and wonder why a lot of NONE appears.
If I want to read NONES I don't select Arm!
greetings - Günter
OK - Try it now - It's fixed.
Yes, I little bit is changed.
But if I search for 'agsi I2c' in all Keil products but only inside the Discussion Forum I get Product News and not the postings where I know that they exists.
And than I think in the Product selection box NONE should be added.
It's a common behaviour that fixing 1 bug produce 2 others... The search dialog contains more unexpected results.
Finished ... not really
