AGSI: get the memory value on memory write trigger
I have the following setwatches:
  Agsi.SetWatchOnMemory(addr, addr, check_data_write, AGSIWRITE);
  Agsi.SetWatchOnMemory(addr, addr, check_data_read, AGSIREAD);
What I try to do is to trigger different functions when micro write / read to a memory address. This works fine except that there are unexpected triggers since I use AgsiReadMemory and AgsiWriteMemory in these functions (check_data_read and check_data_write).
void check_data_read()
   // return some data to the micro
   // by calling AgsiWriteMemory()
void check_data_write()
   // check what micro wrote
   // by calling AgsiReadMemory()
Is there a way to prevent these unexpected function triggers? I mean how can I know what micro wrote to that addres without using AgsiReadMemory? or how can i return a value to the micro on memoryread without calling AgsiWriteMemory?
