Hi all,
I'm using the RealView MDK-ARM with the RealView Realtime Libary. At the moment I'm working on building a small embedded webpage for the MCB2300.
Everything works fine, but the fcarm tool used to create the small filesystem that holds the files for the webserver, might need an improvement.
I have the problem that I'm using javascript in the HTML files. So have lines off text with backslashes like:
... t if(ValueString.match(/^\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3}&/ t { t alert("IP matches format\n"); t } t else t { t alert("IP doesn't matches format\n"); t } ...
The fcarm already maskerades the " with \". But it doesn't do it with \. So I have to mask the \ manually with \\ like in the following example.
... t if(ValueString.match(/^\\d{1,3}\\.\\d{1,3}\\.\\d{1,3}\\.\\d{1,3}&/ t { t alert("IP matches format\\n"); t } t else t { t alert("IP doesn't matches format\\n"); t } ...
I think such an improvment would be easy to implement. Why isn't it already implemented?
Rainer
Hi Rainer, I faced a different problem with FCARM. I have a stylesheet boudled with my pages (.css file) and I suspect the tool is not recognizing its extension and making a "binary" representation out of it. This seems to break the stylesheet behaviour on Mozilla browsers. I suspect this being due to incorrect/incomplete string termination.
Anyway... please let me know if you received any help on the tool or if you found any documentation about fcarm options other than this minimal help page ( http://www.keil.com/support/man/docs/rlarm/rlarm_tn_fcarm.htm )
TIA
Andrea
Hi Andrea,
as far as I know, Keil has solved the issue with the backslash in the javascripts in their latest update. But I didn't have time to test it because I'm in a critical state on writing my diploma thesis. I'm still working with the old version embedded development toolkit 3.04.
In the case of css I can shortly desribe my experiences only: 1. Html-files with embedded css statement work fine. 2. Seperate css-files which are linked to a html-file through a kind of include tag in the header doesn't work properly.
I used an example webpage with seperate css-file which worked on my PC, moved them to the keil embedded webserver and the css didn't work. I didn't have time to address the problem properly, but I assume the FCARM tool doesn't recognize css-file with their special meaning and so it doesn't work.
As a workaround I used the scipting functions. I put all the css information in a central include file with the html tags and input that through the i command into the files.
Example:
File with central css statements: cssfile.inc: (must have the ending "inc"!)
<style type="text/css"> ... css statements (don't use comments, it doesn't work) ... </style>
scriptfile with orginal html-content: hello.cgi (must have ending "cgi"!)
t <html> t <head> # includes central css information i cssfile.inc t </head> t <body> t <h1>Hello World</h1> t </body> t </html> .
I'm using a index.html with a frameset that links to the cgi script files.
I hope that helps you...
We have fixed this problem. The fix will be available in the next RL-ARM release. If you need a fix now, please send an email to Keil support.
Franc
