TWIN-CAN and dave
I used DAVE to get the basic setup for the twin-can module of an XC161.
In the suggested code I found some "funny" lines
#define CAN_TXIPNDL          (*((uword volatile far *) 0x200288))
#define CAN_TXIPNDL_TXIPND0  ((T_Reg16 *) 0x200288)->bit0
if(CAN_TXIPNDL & CAN_TXIPNDL_TXIPND0)   // message object 0 transmit interrupt
I thought CAN_TXIPNDL_TXIPND0 is already a bit variable. IMHO the boolean expression is nonsense. The following expression should give me the same result:
if(CAN_TXIPNDL_TXIPND0)
Just to be shure, am I right or not?
Leo
  • My advise would be to check to see if there is an update on the Infineon web site for the Dave plug-in you are using.
    Why, in my opinion both statements are incorrect (unless you have a DPP set to page 0x80). Since you are trying to read a bit from an address that is not near thus incorrect. You need to make that the pointer to the bit is "far", "huge" or "xhuge".
    For example:
    #define CAN_TXIPNDL_TXIPND0  ((T_Reg16 far *) 0x200292)->bit0
