I'am started to learn ARM7 and Keil uVision not so long ago, and I've got a problem with its simulator. SSC transmitter does not activated (i.e. SSC_CR register still equals zero) after executing this code: pPMC->PMC_PCER = (1 << AT91C_ID_PIOA) | (1 << AT91C_ID_SSC); pSSC->SSC_CMR = 2; //SSC Clock = MCLK/4 pSSC->SSC_CR = AT91C_SSC_SWRST; //Software reset pSSC->SSC_TCMR = AT91C_SSC_CKO_DATA_TX; //Transmitter clock mode pSSC->SSC_TFMR = 15 | AT91C_SSC_MSBF; //Data word is 16 bit, MSB first pSSC->SSC_CR = AT91C_SSC_TXEN; //Enable transmitter
Don't know why, but I was unable to set any bit in SSC_CR register in the simulator - neither by the code execution, nor through it's interface window. This register is always at zero.
Is that a bug?
PS: I'am also did not find any SPI interface window/panel for AT91SAM7S in the simulator. Does it exist?
