My Multi-ICE is ok in AXD Debuger of RVDS 2.2, but cannot use in MDK 3.03/3.04. When i start the debuger, a dialog shows up titled with "AgdiRDI": "Multi-ICE - Before you can use the debuger, you must select a processor using the configuraton dialog. Click On configure to display the dialog". The Multi-ICE server is running ok, and I think the configuration is ok. The configure process:
1.In the Debug option dialog, Use: RDI Interface Driver, click Setting.
2.Browse Multi-ICE.dll
3.click "Configure RDI Driver" to start Multi-ICE Setup
4.A processor ARM7TDMI is in the connecting. select the processor and click OK.
why the debuger still tell me to choose a proccessor?
