I use the MCB-STR9 eval board.
I use Flash Bank 0 for program and Flash Bank 1 for my Parameter. Do write some Parameters I have to clear the first sector of this Bank while runtime. But I got a timeout or an Prefetch Interrupt.
I have a short demo programm. (you can find under http://www.gds-sw.de/keil the complett demo programm for the eval board)
Whats wrong?
Rainer Fuchs GDS GmbH Karl-Götz-Str.5 97424 Schweinfurt Germany
If you want to correctly write on the flash bank1 when you execute code from bank0, you have at least to put the content of this function in RAM :
FMI_Config(FMI_READ_WAIT_STATE_3, FMI_WRITE_WAIT_STATE_1, FMI_PWD_DISABLE,\ FMI_LVD_DISABLE, FMI_FREQ_LOW); /* FMI Waite States */
The fmi controller doesn't reconize this init if the code is executed from flash. You can locate the CONTENT (the two writes to FMI_BANK1) of this small function in a dedicated source file named INRAM.C, and next add inram.o in your linker setup file (blinky.sct)
RW_IRAM1 0x04000000 0x00018000 { ; RW data * (+RW +ZI) inram.o }
if you have futher problem you can also replace inram.o by directly 91x_fmi.c in the linker file to locate all flash routine in RAM at the execution. with this, everything must be good.
I hope that can help you.
Chris.
