C51 - Calculating the parity
Has someone a good hint how to implement a parity-calculation of a byte in the most efficient way on an C51-device?
  • implement a parity-calculation of a byte in the most efficient way on an C51-device
    convert that routine to assembler, in assembler you have a parity bit in the PSW. That bit is not accessible in C since C is not register specific
  • "That bit is not accessible in C since C is not register specific"
    The bit is accessible - the doubt is whether it relates to what you want at the time you want it...
    Several people have suggested doing this in C51 - just do the Search to find it.
    You may be lucky, but I'd put it in an assembler function.
  • Hi,
    Just have dealt with this problem recently.
    May I share what I learned. One must calculate the parity right before using it. The ACC is a very busy fellow.
    Ed.
  • "One must calculate the parity right before using it. The ACC is a very busy fellow"
    Yes - that's why I urged caution in doing this in 'C':
    "the doubt is whether it [the parity flag] relates to what you want at the time you want it..."
    I still say assembler is preferable...
  • absolutely
    Relying on a register in C is, at best, a kludge.
    Many will not use assembler because they believe that 'portability' is 'interesting' for code for small embedded, BALONEY. The only reason for using C with small embedded is coding and maintenance ease. Of course, a C function not using any I/O for small embedded is somewhat portable, but the C postulate that the whole shebang is portable is totally invalid for small embedded.
    BTW how would ACC = Ralph; george = P; ever be portable.
    PS if this is because you can not write it in assembler, I pity you.
  • "I still say assembler is preferable..."
    Agreed.
    If using C and without relying on results being in particular registers, the expressions below yield a parity bit in bit 7 for OR'ing with 7-bit data.
    #define EVEN_PARITY(b)  ((((((b)^(((b)<<4)|((b)>>4)))+0x41)|0x7C)+2)&0x80)
    #define ODD_PARITY(b)   (EVEN_PARITY(b)^0x80)
  • excellent example of the cost of portability. Many that have more concern for 'purity' (which, probably, is a great idea for PC code) end up with high hardware costs, simply because they do not ralize that, in small embedded, efficiency is the name of the game.
  • "excellent example of the cost of portability"
    Actually, it's a poor example. Some other example would demonstrate the cost much better. On the non-8051 architecture where this is used, the expression compiles to the same 6-instruction sequence as the hand optimized assembly.
    I am away without access to my C51 toolchain at the moment to include the compiler-generated assembly, but you will find with the http://www.keil.com/support/docs/1619.htm and its function parameter and call/return overhead, that the non-portable function and portable expression versions compare quite closely.
    That's why if you want to shave off a few bytes and cycles, you should write it assembly, but do it inline within a larger assembly module that uses the parity, otherwise you've still got the overhead of a function call without benefit.
  • That's why if you want to shave off a few bytes and cycles, you should write it assembly, but do it inline within a larger assembly module that uses the parity, otherwise you've still got the overhead of a function call without benefit.
    Dan, you are right; however I see a possible misunderstanding of your stetement and thus, without any malice, I correct it
    "but do it within a larger assembly routine that uses the parity"
    On my first read I read 'inline' as "inline assembly in a C module"
  • Once again I agree substantially with what is said above about mixed-mode development and non-portable implementation.
    However, there are some things that simply don't justify the cost of a function call. One of such things is exactly the parity function in a '51 derivative.
    If you are in C, you can get the parity in 2 machine instructions:
        d = 0x54;
        if(ACC=d, P)            // if odd parity
            d = 0x55;
            par = (ACC=d, P);   // par is 1 for odd, 0 for even.
    The expression (ACC=value, P) uses the comma operator to guarantee that the accumulator will not be dirty before testing the PSW.P bit. It is an ancient C trick to force the compiler to perform low-level operations in a certain sequence.
    Albeit not 'portable', it is ANSI, and that use of the comma operator is guaranteed not to be optimized by the compiler.
    It produces a parity evaluation in 2 machine instructions. I doubt that this can be done faster in any other implementation.
  • The comma operator is perfect for yet another nice trick: update a 16bit timer in C, by adding the 16bit value of the period constant to the timer registers:
    // The following macros reload the 1ms timer, compensating for the interrupt
    // latency to achieve an average frequency of 1ms, corrected at every period.
    // The code uses a few C tricks:
    // - Accesses the PSW carry directly, to obtain the overflow from an unsigned
    // char addition. We use the comma operator for that, to perform a side effect
    // addition right before of a carry bit test, not allowing the compiler to
    // reorder the code and make the carry dirty.
    // The comma operator is used also to insert padding NOPs before the addition,
    // in the cases that the lower byte of the adjust value is {0,1,2}, because the
    // C51 compiler generates INC instead, or suppresses the operation.
    // This code was verified with optimization levels from 0 to 9, and the compiler
    // doesn't try to break the code with optimizations.
    // The whole procedure is wrapped in a function-like macro.
    // This code was verified in a P89C668 @18.432MHz, and the frequency deviation
    // measured was ±20ppm, essentially the cpu crystal variation, completely
    // removing the timer interrupt latency.
    #ifdef ADJ_DELAY
    #undef ADJ_DELAY
    #endif
    #ifdef RELOAD_TIMER0
    #undef RELOAD_TIMER0
    #endif
    #if (((TMR_1MS & 0xff) < (0xff-8)) || ((TMR_1MS & 0xff) > (0xff-6)))
    #define ADJ_DELAY 9
    #define RELOAD_TIMER0()     do {                            \
                                    TR0 = 0;                    \
                                    if (TL0 += ((TMR_1MS & 0xff) + ADJ_DELAY), CY) TH0++;   \
                                    TH0 += (TMR_1MS >> 8);      \
                                    TR0 = 1;                    \
                                } while(0)
    #elif ((TMR_1MS & 0xff) == (0xff-6))
    #define ADJ_DELAY 10
                                    TR0 = 0;                    \
                                    if (_nop_(), TL0 += ((TMR_1MS & 0xff) + ADJ_DELAY), CY) TH0++;  \
                                    TR0 = 1;                    \
                                } while(0)
    #elif ((TMR_1MS & 0xff) == (0xff-7))
    #define ADJ_DELAY 11
                                    TR0 = 0;                    \
                                    if (_nop_(), _nop_(), TL0 += ((TMR_1MS & 0xff) + ADJ_DELAY), CY) TH0++; \
                                    TR0 = 1;                    \
                                } while(0)
    #elif ((TMR_1MS & 0xff) == (0xff-8))
    #define ADJ_DELAY 12
                                    TR0 = 0;                    \
                                    if (_nop_(), _nop_(), _nop_(), TL0 += ((TMR_1MS & 0xff) + ADJ_DELAY), CY) TH0++;    \
                                    TR0 = 1;                    \
                                } while(0)
    #endif
    In the timer handler, a call to RELOAD_TIMER() invokes the macro, that is synthesized for any reload value.
  • Another use of the comma operator: you can get the 16bit result from the multiplication of 2 unsigned char without any call to the math clib:
        unsigned char data a, b;
        unsigned int data x;
        a = 36;
        b = 130;
        // this is 400% faster than a x = (unsigned int) a * b
        *(unsigned char*)&x = ((((unsigned char*)&x)[1] = a * b), B);
    I am just too lazy: you can make the int variable a union to access the msb and lsb parts, to improve readability, but the generated code is the same: 11 instruction cycles against 40 cycles using a 16bit cast.
  • Here's a simple one:
    static char const code nibble_parity[16] =
                       { 0, 1, 1, 0,
                         1, 0, 0, 1,
                         1, 0, 0, 1,
                         0, 1, 1, 0 };
    char calc_even_parity(uchar byte)
        return( nibble_parity[byte&0xf] ^ nibble_parity[(byte>>4)&0xf]);
    char calc_odd_parity(uchar byte)
        return(!calc_even_parity(byte));
    I've been using it for years
