I tried to program the flash on the MCBSTR7 eval board (HITEX STR7) using the STR_IAP code (via UART) which I downloaded from KEIL website. The code was compiled property with a minor warning but after I loaded into the flash assuming that it went to IAP section of the chip. After the board was reboot, and the HYPER terminal was running (according to instrucion on AN2078 from STmicro), the board did not response to "sending file command" from terminal program --- eventully timed-out Does anybody in this forum sucessefully has used the STR_IAP ver2.0 with the MCBSTR7 eval board? please share you experience. Thanks in advance
