armlink/scatter
Hi folks,
I'm trying to link from the command line using the armlink that's at \Keil\ARM\BIN30\armlink.exe
The help for armlink shows, in part:
--scatter file Create the memory map as described in file.
Yet when I try to tell it to use a scatter file, it says:
Fatal error: L3900U: Unrecognized option '--scatter'.
I wonder if this is my problem:
ARM Linker, RVCT3.0 [Build 934] for uVision [Evaluation]
Is the Eval copy a problem? Further followup on this: why is this showing eval still after licensing uVision? I suspect I know the answer, but I don't know for sure.
So,
(1) does the eval version of armlink just not support --scatter?
(2) why is armlink still showing as eval with a licensed ARM Toolkit from Keil?
Steve
