philips reg924.h redefinition
in byte registers ,it declares
sfr CMP1 = 0xAC;
sfr CMP2 = 0xAD;
while in bit registers it declares
sbit KB7 = P0^7;
sbit T1 = P0^7;
sbit KB6 = P0^6;
sbit CMP1 = P0^6;
sbit KB5 = P0^5;
sbit CMPREF = P0^5;
sbit KB4 = P0^4;
sbit CIN1A = P0^4;
sbit KB3 = P0^3;
sbit CIN1B = P0^3;
sbit KB2 = P0^2;
sbit CIN2A = P0^2;
sbit KB1 = P0^1;
sbit CIN2B = P0^1;
sbit KB0 = P0^0;
sbit CMP2 = P0^0;
Is it a error?
IDE-Version:
uv ision3 V3.30
C Compiler: C51.Exe V8.02
thanks
  • sfr CMP1 = 0xAC;
    sbit CMP1 = P0^6;
    my horse is named Phred
    your horse is named Phred
    both are in the same stable
    Joe show up at the stable and tell the attendant to go get Phred
    Got it?
  • Is it a error?
    Yes.
    And it's not the only include file that has errors. aduc845.h, for example, has some, too.
  • When you fix the errors, I suggest that you change both of the names; eg,
    sfr CMP1_SFR = 0xAC;
    sfr CMP2_SFR = 0xAD;
    sbit CMP1_SBIT = P0^6;
    sbit CMP2_SBIT = P0^0;
    (those names are purely by way of illustration - I'm sure you can think of far better ones)
    that way you won't have any old code that thinks it's found the symbol it wanted, but actually it's the wrong one!
    Also, be sure to comment the changes clearly.
    Leave the old names in the comments, so that a text search will find them when code fails to build because it wanted one of the old names.
  • the problem here is that Keil "mindlessly" makes a .h file (no blame, what else can they do).
    Then when the chip has a SFR, a bit and a pin with the same name which may not be too confusing in a datasheet, the "mindlessly" generated .h end up with such errors.
    for this reason and the one below I never use the "canned" .h files.
    A real problem with the "usual" names of SFRs and bits is that a global search will never get all uses of a certain bit and I can tell of numerous cases where a "hidden" use of a bit caused a lenghty debugging session.
    you may have setb TR0
    and mov TCON, #010h
    and you will miss one or the other when you search.
    my .h files look like this (an extract related to TR0)
    sfr     SF_TCON         = 0x88;
      sbit    SB_TCON_TR0     = 0x8C;
      #define SM_TCON_TR0       0x10
    making the above
    setb SB_TCON_TR0
    and mov TCON, #SM_TCON_TR0
    thus any search on TCON will find any access to that SFR, any search on TR0 will find any access to that bit.
  • "the problem here is that Keil "mindlessly" makes a .h file..."
    The problem is the file that doesn't even compile!
    The file should not have been released if it doesn't even compile!
  • The file should not have been released if it doesn't even compile!
    agreed
