Hello, since a few days I'm working with uVision3. The Target-HW is a LPC2294 on a phyCORE HD200-Board, the flashing works with a ULINK-USB-Adapter. Examples like Hello and Blinky are working fine, but now I have problems with the example EasyWeb. Flashing the board with EasyWeb often results in an error-message (see below) but not always!!! Sometimes the flashing works fine! Does anyone have an idea what's going wrong with it?
Error-Message: In PopUp-Window: "Error: AM29x800BTx2.FLX" "Cant't Load Flash Programming Algorithm!" In Output-Window: Load "C:\\Programme\\Keil\\ARM\\Boards\\Phytec\\LPC229x\\EasyWEB\\Objects\\easyweb.ELF" Include "C:\\Programme\\Keil\\ARM\\Boards\\Phytec\\LPC229x\\EasyWEB\\Flash.ini" /***********************************************************************/ /* This file is part of the ARM Compiler package */ /* Copyright KEIL ELEKTRONIK GmbH 1992-2004 */ /***********************************************************************/ /* */ /* FLASH.INI: Flash Initialization File */ /* */ /***********************************************************************/ //*** <<< Use Configuration Wizard in Context Menu >>> *** FUNC void Setup (void) { // <h> External Memory Controller (EMC) // <h> Bank Configuration 0 (BCFG0) // <o1.0..3> IDCY: Idle Cycles <0-15> // <o1.5..9> WST1: Wait States 1 <0-31> // <o1.11..15> WST2: Wait States 2 <0-31> // <o1.10> RBLE: Read Byte Lane Enable // <o1.26> WP: Write Protect // <o1.27> BM: Burst ROM // <o1.28..29> MW: Memory Width <0=> 8-bit <1=> 16-bit // <2=> 32-bit <3=> Reserved // </h> _WDWORD(0xFFE00000, 0x20003CE3); // BCFG0: Flash Bus Configuration _WDWORD(0xE002C014, 0x0E6001E4); // PINSEL2: CS0, OE, WE, BLS0..3 // D0..31, A2..23, JTAG // </h> } Setup(); // Setup for Flash Cannot enter Debug Mode *** function 'Setup', error 125, line 28: AGDI: memory write failed (0xFFE00000) Can't Write to RAM for Flash Algorithms ! Erase Failed!
Please see: http://www.keil.com/support/docs/2747.htm
Thanks for the answer, but that information doesn't really help me. The problem is, that the error occurs only sometimes. In much cases the flashing works fine. The settings for the Flash Programming Algorithm are the default settings as they described in the HW-Manual: Flash Programming Algorithm: LPC2000 IAP 256kB Flash (0x00000000 - 0x0003DFFF) AM29x800BT (0x80000000 - 0x801FFFFF) RAM for Algorithm: Start: 0x40000000 Size: 0x0800 I can't see any errors in this settings. The problem happens only with Ethernet-Applications (such as EasyWEB), all other Demos are working faultless! Or is it a problem with the settings for the developmentboard HD200? Any ideas? Thanks in advance!
Maybe the EasyWeb example overwrites the memory. Is it really configured for running from Flash?
The code of the EasyWEB-Example was changed by Keil for the LPC2294 and I didn't change the configuration. So in my opinion the example should run from flash on the LPC2294. By the way I have found another Ethernet-Demo-Application for the LPC2294 by CMX. While flashing the error occurs sometimes too, but if the flashing doesn't fail the application works successfully. Therefore I have doubts that the reason is a problem of configuration (and also i think the error should happen any time when a configuration-problem occurs!?!?).
