BL51: '*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL'
I am designing an application to run on the Si Labs
C8051F046 MCU with uVision 3. Yesterday I created a new
project, but forgot to include one of the source modules.
This produced a line during the link in the Output Window:
I missed it, as this program generates many similar warnings:
  *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
(in that tiny, little output window) which I must ignore.
Because L1 is only a warning; BL51 completed the build and
gave me a load module, which I attempted to debug. (It came
fairly close to working). I wasted an hour tracking the
cause back to this source.
I can't think of any scenario where I would want the build
to continue with missing source modules, yet I can find no
tool that would allow me to make L1 an error instead of a
warning. As best I can tell, this topic has never appeared
in the knowledge base or on this forum.
Does anybody have a differing opinion? A workaround?
Advance thanks for any insight.
Gary Lynch            |     To send mail, change no$pam in
lynchg@no$pam.com     |     my domain name to stacoenergy
  • "this program generates many similar warnings ... which I must ignore."
    Why must you ignore them?
    Have you not just proved the folly of ignoring warnings?!
  • "I can't think of any scenario where I would want the build to continue with missing source modules"
    How about If you were doing some sort of "incremental build", or you were building a Library that required some call-backs to be provided by the user?
    Anyhow, if the functions in those modules are never called, and the data is never accessed, what difference does it make!
    "yet I can find no tool that would allow me to make L1 an error instead of a warning."
    As soon as you actually try to reference one of the undefined symbols, that most certainly will give you an error.
  • which I must ignore. Because L1 is only a warning;
    Many decide to ignore warnings, that may be OK during development, but there is a difference between "ignore" and "not read"
    I may ignore warnings during development, but I ALWAYS read them
    I can't think of any scenario where I would want the a) build to continue with missing source modules, b) yet I can find no tool that would allow me to make L1 an error instead of a warning.
    a) the warning is NOT "missing source module" but "missing reference" I often accept a build when that comes up. e.g. in the first stages of a debug, you may have a function that is not called with an unresolved reference. b) such an option might be nice.
    Several reasons:
    • This board is one of 5 using the same MCU. I frequently
      borrow a driver from one board to use on the other. The
      old driver may contain multiple functions which I have not
      yet implemented on the new hardware, and aren't called by
      my test suite.
    • I have developed a suite of functions I find extremely
      useful in debugging, but are not a part of the final
      application, which I keep in a separate source file. I
      don't call all of them when I need help debugging.
    • I implement a state machine with a table of function
      pointers. This interacts with an idiosyncracy of BL51
      to make it jump to the (erroneous) conclusion my
      functions are calling themselves recursively. Keil has
      an app note detailing a workaround for this, but it is
      such a hassle to get the syntax right, I frequently let
      BL51 whine.
    So although I don't expect to have any warnings in my final
    release, the debug process is not that simple.
    I also find it extremely difficult to review the list of
    warnings (accurately) in that little slit that passes for an
    output window. If anyone has found a way to pass the build
    output to a text file I could open with my text editor, that
    might make it worth the trouble.
  • This interacts with an idiosyncracy of BL51
    The linker is not making any erroneus conclusions. It tries to construct a calling tree for your functions, but fails as soon as function pointers come into play since the Linker has absolutely no idea what values the function pointers will have during run-time. It therefore makes the right decision by not considering those functions for overlaying.
    Don't blame the linker for perfectly expected behavior.
  • I also find it extremely difficult to review the list of
    output window.
    Have you tried resizing the output window ? Works fine for me ...
  • "Have you tried resizing the output window ? Works fine for me ... "
    All the Linker messages are saved in the Linker Listing file (the "Map" file).
    Just as the compiler messages are in the compiler listing files.
    I think the build window content is also saved to a file - maybe .plg ?
    You can also copy-&-paste from the output window.
    With Windows XP, you could probably even get it to read the warnings to you out loud...
  • With Windows XP, you could probably even get it to read the warnings to you out loud...
    Doing this at your workplace without headphones would amount to severe Wally-esque behavior.
  • I think the build window content is also saved to a file - maybe .plg ?
    Yep. In HTML, no less.
  • "I implement a state machine with a table of function pointers. This interacts with an idiosyncracy of BL51 to make it jump to the (erroneous) conclusion my functions are calling themselves recursively. Keil has an app note detailing a workaround for this, but it is such a hassle to get the syntax right, I frequently let BL51 whine."
    I'd say that's almost certainly the reason why your application failed in the first place!!
    You've read the app note, so you know that this is due to a fundamental feature of the 8051 architecture. If you disregard that and and just plough on regardless, you are positively asking for trouble!
    Yes, tables of function pointers are great for implementing state machines - but you have to weigh this against their cost on the 8051 (ie, having to cope with the Linker's foibles).
    If getting the tools configured is too much for you, then you need to look for another solution.
    Personally, I'd have loved to have used my normal function-pointer table approach to FSMs, but found all the manual Linker tweaking far too risky - so I used switches instead.
    Your call.
    > "not read"
    > them
    Ok, so oversimplified my process. I read ALL the warnings
    the first time I link a new module and take action as
    indicated. But some of them are not eliminatable.
    Thereafter I only read the body of the warnings if the
    NUMBER of warnings changes from the prior build. In the
    case cited, I went too fast and confused "UNRESOLVED" with
    "UNCALLED".
    Ok, I'll grant you that scenario. It's just that I've never
    used it.
    > make!
    <snip>
    > error.
    Well, you want the dirty details, here they are. The source
    containing the main() function looks like (names have been
    changed to protect the guilty):
    while(1) {
      for(j=0; j<6; j++) {   | ?C0001: CLR     A        ;  1
                             |         MOV     j,A      ;  2
                             |         MOV     j+01H,A  ;  3
                             | ?C0003: CLR     C        ;  4
                             |         MOV     A,j+01H  ;  5
                             |         SUBB    A,#06H   ;  6
                             |         MOV     A,j      ;  7
                             |         SUBB    A,#00H   ;  8
                             |         JNC     ?C0001   ;  9
        doFoo(2, j);         |         MOV     R5,j+01H ; 10
                             |         MOV     R7,#02H  ; 11
                             |         LCALL   _doFoo   ; 12
        wait(4473);          |         MOV     R7,#079H ; 13
                             |         MOV     R6,#011H ; 14
                             |         LCALL   _wait    ; 15
      }                      |         INC     j+01H    ; 16
                             |         MOV     A,j+01H  ; 17
                             |         JNZ     ?C0007   ; 18
                             |         INC     j        ; 19
                             | ?C0007: SJMP    ?C0003   ; 20
                             |         RET              ; 21
    } /* END while(1) */     |                          ; 22
    I tacked the assembly produced by C51 onto the right side
    for reasons that will become apparent later. I also added
    line numbers to facilitate discussion. Variable j is an
    unsigned int.
    The module I forgot to add holds function wait() (which is a
    thumb-twiddling loop whose execution time I can control with
    the argument shown). The object module produced by the
    compiler sets wait()'s address to dummy value c:0x0000
    (a.k.a. your friendly neighborhood power-up vector).
    The linker issues its warning:
    *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL
        SYMBOL:  _WAIT
        MODULE:  TestFoo.obj (TESTFOO)
        ADDRESS: 01BEH
    and the execution module gets built, assuming wait() is
    still at 0000.
    As compiled, the "j=0" part of the for-loop consists of the 3
    instructions beginning at line 1; the "j<6" code is in
    lines 4-9, while the "j++" term resides in lines 16-19.
    This baby executes exactly as I intended until we get to the
    call to wait(). At this point, it performs the moral
    equivalent of a power-on reset, putting control back at the
    top of the loop with j=0. Thus my program executes the
    infinite loop I had wanted, but j never deviates from 0.
    This is the scenario that prompted this post.
  • There seems to be two communities of users of the Keil '51 software:
    There is the "C is C" community that refuse to accept that the '51 is weak in certain respects which makes it advisable to avoid certain constructs. I guess that those also do not use the unique features of the '51 that makes it strong in other respects:
    Then there is those that adapt to the realities:
  • I think it should be possible to use function pointers in C51 without having to manually tweak the Linker's call tree?
    On the other hand, I know that the switch approach works.
    Hence my choice!
    But you have nevertheless accepted reality :)
    Everyone has something they would like to see different, it may and may not be included in the next release. Do I have 'things', absolutely. Do I sit doen and whine about them? abaolutely not.
    Now, for a real BUG. I would send 47 e-mails every day till it was fixed.
